raf arero kits tender plans
Iniciado por Stephen T
32 replies 60 me gustas Última actividad: hace 4 años
#33 1
If it’s to run a thumper motor definitely a 11.1v
I tried a 7.2v battery but it was far too slow
My battery is about 150mm long 48mm wide and 25mm deep (see pic) and it sits sideways in my boat behind my motor
Le gusta a BOATSHED and Colin H
#32 1
thanks for that all written up in the note would one battery do 11.1 or 7.4 what do you use
Stephen james tucker
Le gusta a BOATSHED
#31 1
Scoop behind the propeller and the water gets pushed through so no need for a pump, mine has been fine and have run it for 10 years.
Le gusta a RonBMK2 and BOATSHED and
#30 1
thanks for that so NiMH it is as with me if will go wrong it will so two 11.1 for the Duseldolph and one for the raf boat what size ones I was going with a thumper engine i have have a water cooled esc so ill need a inline filter? do i need a supply pump as well or just rely on the scoop sorry about all the question
#29 1
I'm with you on that issue Colin. LiPO's are a needless cause of anxiety for me. Prefer SLA, gel-cells for their ballast value...& NIMH when a lighter battery is desired without the hazards of Lipo. I do hav LIPO chargers, & a few LiPOs. Yes a LIPO can provide longer runtime for less battery weight however in our Canadian society obtaining birdshot & other dense weights is problematic. I hav used rolls of old subway tokens (tube tokens), rolls of pennys & nickels, as lead is quite expensive. Have even used a few iron nails embedded in RTV silicone cement. They get heavier as they are rusting. Best 73 de VA3ROD
VA3ROD
Le gusta a BOATSHED and Stephen T and
#28 1
I have just weighed my 11.1v lipo battery and it weighs 356g and I have weighed a 12V NIMH battery and it weighed 576g so consider the weight when you make your battery choice.
On the flip side, my NIMH batteries are stable and have given me years of use, whereas I am on my second lipo battery as the first blew up like a balloon and had to be scrapped.
Le gusta a BOATSHED and Rowen and
#27 1
Is there a possible request for another copy Pretty lease?
BOATSHED
Le gusta a RonBMK2
#26 1
Westwood, I have never tried lipo's, I'm old school, nicads, nimh's, and sla is what I've always used. In a small boat like my crash tender I can't use my preferred batteries SLA in 99% of my models.
I'm too old to change now.
Le gusta a RonBMK2
#24 1
Here is my 34 inch aerokits version over 60 years old now, but still works fine.
Cooling water exits via the exhaust tubes in the stern.
The monitors are fixed position but operate very well using an old 6 volt car windscreen washer pump switched by a microswitch operated by servo arm.
The intakes for Cooling and the monitors are just behind the prop.
All run from 7.2v nimh batteries.
Le gusta a BOATSHED and lindemann06 and
#23 1
That would be excellent, I’ll send you a PM with details
Le gusta a BOATSHED
#22 1
Hi Neil
I’m putting a CD together for Westward with some bits and pieces I’ve collected over the years. If you pm me your address I’ll send you one as well if you like?
Neil
#21 1
So glad I found this site. I picked up what I believe to be an old Aerokits RAF Tender via Facebook Marketplace. I really shouldn't have as there's already a number of projects in the workshop, but I couldn't refuse it. So far progress has consisted of giving it a good looking at, removing the old prop tube (came out very easily), making good a couple of dents in the hull and starting to get the hull primed.
As there's not a huge amount to do to I was thinking about monitors that move and pump water. Just wondering what the best options are for getting working monitors and if those of you who have done this are able to share what works.
Also, if anyone has the plans they would be willing to share I would be very appreciative.
thanks
Neil
Le gusta a Colin H and neilmc
#18 1
forgot to say I see the prop has a silicon o ring it and grease of some sort yes
Le gusta a BOATSHED
#17 1
that explains that where does the water go out some one was going to fit working fire pumps like the ones hobbies sell these go via pump motor i guess
#16 1
The water pick up faces forward and is just behind the propeller so the propeller pushes water into the pickup pipe to cool the ESC and the water cooled engine mount.
The other pipe behind this in the photo is the pick up pipe for the water pump that squirts water out of the two fire monitors.
Le gusta a BOATSHED
#15 1
sorry to be a pain the water cooled esc does that use the water scoop under the boat and then put it out the side and does the scoop face forwards or back wards or would you use a non water-cooled one as do they get hot as you can I am not electrically minded but learning fast
Le gusta a BOATSHED
#14 1
My hull is 34.5 inch and the running gear is
Hobbywing 90 amp speed controller, Overlander Thumper T3548/05 60Amp outrunner brushless motor, 11.1 V Lipo battery and 45mm three blade prop is my set up and it runs just about perfect.
Le gusta a lindemann06 and Colin H and
#12 1
I have built two 93 and 94
Both have moving and working monitors.
I run them using an Overlander brushless motor on 11.1v lipo battery with a 45mm three blade propeller and get about an hours run time which is very good considering how fast they are on the lake.
Le gusta a RonBMK2 and Colin H and
#11 1
yes i too have now two Raf tenders and unfinished kit at one time there was lots of these boats about be an interesting this for the site a register of what types of bots people have or if there is I've never seen one, I have been pleasantly surprised in the friendly ness of people with boats my other hobby is live steamers and it isn't so sociable as it used to be full of plonk it downers now
Le gusta a Colin H and BOATSHED and
#9 1
This is great to see some RAF Crash Tender stuff on here again, this is the second in a few days I have seen. This site started of as a Crash tender site and that's why I joined. Don't get me wrong yes it's good to see all sorts of other boating things, but I am one of those who are mainly only into the Vosper styled hulls, MTB's and the like and then fast Power Boats. But I find scale and sailing boring myself🙊
. I accept we are all different and all have other tastes and styles. But the RAF Crash Tender's seem to be way on the back step on here now. I know there will be quite a few comments regarding what I have said and I am not saying that you shouldn't like other likes, and yes I do read lot's of them and do get idea's on ways of building and fitting out things but I am just a speed freak I suppose and also the Aerokit all boats as I have 4 different ones of them and just love the MTB styled hulls.I'll Just say a big sorry now 🙉🙉🙉.
BOATSHED
Le gusta a neilmc and Colin H
#8 1
I have quite a few bits I could email if you’d like?
If you private message me your address I’ll send them over.
Thanks Neil
Le gusta a BOATSHED
I will look tomorrow for the plan when I am back home
Le gusta a BOATSHED
I think that I have a plan for the 34.5 inch crash tender from when I built mine.
If I can find it would that be of any help to you?
Le gusta a BOATSHED
Hi,
Welcome to the site. There are several blogs on the site covering the build or refurb of RAF tenders. Go to the ‘blogs’ area and use the search facility to look for ‘crash tender’. Hopefully that will help answer many of your questions.
Graham93
Le gusta a BOATSHED and dave976
does any one have any plans for one of these boats i have one to restore thanks and any tips be most welcome
Le gusta a BOATSHED
