Building a cabin
Iniciado por garyp
0 replies 0 me gustas Última actividad: hace 4 años
Building a cabin
Hello. I have decided to build a cabin for my R/C boat. I have plywood, plans and enthusiasm. However I have the skills of a amoeba when it comes to woodwork and ask the following advice.
Which is the best method of cutting and shaping 3mm plywood?
Is yacht varnish better that normal varnish.
Can you get small hinges so cabin can pop up to allow access to internals.
Glue the panels together or screw them together.
Thank You.
Gary Pressman
