MTB rebuild
Iniciado por Muskrat
7 replies 6 me gustas Última actividad: hace 5 años
MTB rebuild
Back to bare wood then sanding sealer or cellulose dope.”🤞
Le gusta a Muskrat
MTB rebuild
Thanks for your reply but by the time i read this i had already used EZ Kote and it does work well.
Cheers Jon.
j a Easter.
MTB rebuild
Try some Bar coat from an automotive paint factor. I use this when putting cellulose over oil paint. Works well.
Le gusta a Muskrat
MTB rebuild
Hi Colin, Thanks for your reply, That's good news Colin I will get that ordered while i strip the paint off.
Thanks, Jon
j a Easter.
MTB rebuild
Hi Jon, I use ezekote to seal all my wooden boats. And yes rattle cans of all types are okay over it.
If I have to paint oner an unknown type of paint I use a blocking coat which I buy from local auto paint supplier.
Hope this helps, cheers Colin.
Le gusta a Ygagnon
MTB rebuild
Hi Rick Thanks for reply, i was just reading about EZ coat, can you use rattle can paint over that do you know.
Cheers Jon
j a Easter.
Le gusta a Colin H
MTB rebuild
Hi, I am rebuilding and refitting the MTB i bought and having problems repainting the deck as it does not matter what paint i use it pickles. I am stripping all the fittings from the deck at the moment so i can strip all the paint off but i need to reseal it , can anyone recommend a sealer i can use to seal the wood so i can repaint it please.
Cheers Jon (Muskrat)
j a Easter.
Le gusta a Newby7
